Old 01-31-2021, 04:46 AM
rca21d645 rca21d645 is offline
The voltage on the cathode of the audio output(pin 1) supplies 135v to the audio IF, tuner, video IF, and video out circuits. Basically the tube is used as a b+ dropper to supply the lower b+. If you operate the TV with the audio output tube pulled, those other circuits will loose their b+. Good to verify that 135v volts is in the ballpark.
I finally figured it out, one of the 6AL5 tubes wasn't making a good connection in its socket, and after moving it around a bit the audio comes in just fine.
Old 02-01-2021, 12:13 PM
That is why cleaning all tube pins and sockets is one of the FIRST things that I do in any restoration.
Regards,
Phil Nelson
Phil's Old Radios
Old 02-01-2021, 03:44 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Regards,
Phil Nelson
Phil's Old Radios
I had a problem with my Zenith 25MC33 color roundie where it looked like the horizontal AFC diodes had failed, classic symptom. I replaced them only to find the problem was a dirty socket for the horizontal oscillator tube.
Old 02-04-2021, 04:05 PM
The new picture tube arrived today, and after installing it the picture looks great. I have full contrast and the brightness works fully with a nice sharp picture. It looks a bit dim in the photo because it was in a well lit room at the time.
Old 02-04-2021, 04:14 PM
Good deal. And that has got to be about the roundest test pattern one could expect , which means you have it adjusted perfectly.
Old 02-04-2021, 06:06 PM
I'm glad it worked out for you!
It was quite a hassle. First the power transformer, then the vertical output transformer and all the rest of the parts and work that was involved.
