Good advice so far. I would just add that you not try and adjust any internal adjustments. The internal adjustments are for aligning and optimizing the image and signal path when all the components are working correctly. Specialized equipment and knowledge is required to do this. Your problem will not be cured with any adjustment.
Tim |
