Tell you what - assuming you have a trickle charger or some way to keep it topped up, I will send you the near-new battery described back in post# 14, for 35 bucks, shipping included. Just glad to see it have a good home. Just PM me with shipping address and it will be on its way, the $35 on your honor.
Probably no need to open the vibrator at this stage, as the radio probably has low time on it. However there is one component that will definitely need replacing once you get the vibrator running. That's the Buffer Capacitor. It's connected directly across the secondary of the transformer. Its purpose is to prevent arcing/pitting of the vibtr contacts. Back in the day we always changed the Buffer out of hand with every vibtr replacement. And it's guaranteed to be leaky after decades sitting. Not sure what value yours is, but it'll be rated at 1600V or higher.
I do have several 1600 VDC film caps that were for use in TVs and VCRs. Is the capacitance rating crucial in this application? If not I have a .0082 MFD 1600 VDC Film capacitor that I could use in place of the old .005 MFD 1200 unit. |
The thing here is, the vibrator may be fine, the fact that your 6V battery became a one volt battery under load means that you weren't providing the radio with the power it needs. Despite what the ratings say I still don't believe a 6V lantern battery could ever provide the "inrush" power needed to start the vibrator. As you may know about incandescent bulb theory, for a couple of milliseconds upon being powered up the cold filament draws MAD amps, way more than you'd ever believe, to heat the filament to white hot where it's resistance goes way UP and the inrush current subsides. With your vibrator, upon initial application of power the stopped contacts that haven't yet started moving are presenting the transformer's primary winding as an almost dead short to your power source , a microsecond or two later once the vibrator starts that initial inrush of current it took to get the vibrator buzzing subsides to the normal running current of the device (which of course is MUCH lower than the starting current). Old Coot has given you one Hell of a generous offer and I wouldn't be surprised if that battery starts that ol vibrator, if not, only then, provided all the tube heaters and pilot light are on, if it don't start, THEN contemplate taking it apart. As to your fear of hurting something by using the rechargeable battery, remember, the 4A fuse is there to save the day if there are any hard short circuits in the radio. |
Agree...high inrush current may be the problem, BUT a 6 volt lantern battery that measures 5.5 volts with no load is very tired. Results may be different with a fresh alkaline battery. ![]() Agree... OC’s offer is very generous, big thumbs up for OC. jr |
I did then return the 2 Duracell lantern batteries to the hardware store and got my money back, which I'll use for the battery OC is offering me. I have an old 1960s vintage 6/12 V battery charger that was my grandfathers that I can use to recharge the battery that OC is offering me (which I did accept his offer, but I haven't heard back from him yet). |
