Old 05-17-2021, 10:43 PM
svhs's Avatar
svhs svhs is offline
DIGITRON
Lightbulb Sony CRT LCD TV Programming Jig Trace
Trace Programming Tool For Sony Television Ref # Q004924
Put the monitor in helmholz coil.
For Programming I2C Controlled Sony Televisions
Having the 5 pin data connection
Software included ( Runs on windows 2000 or XP )
Interface Connects To I2C Controlled Televisions via the proprietary Sony 5 Pin Data Connector
Found in ALL Sony CRT and many Plasma and LCD Televisions
The 5 Pin connector provides I2C Clock and Data,
Software Enables complete NVM Data transfer from TV to PC , NVM Data Backup, NVM Restore,
Error Code Reading etc, selectable with the trace software by Sony TV Model or Chassis Model # or By NVM Chip Used
This Tool and software Is meant to be used for Sony Television Models only,
Degauss the iron part of chassis with a hand degausser and degauss coil.5. Degauss CRT face with a hand degausser again.6. Input AC 230V to AC IN and turn the monitor off and on. Then auto-degauss works.7. Reset FUNCTION_SW bit1 to 0 (auto-degauss = off)8. Degauss CRT face with a hand degausser again.9. Attach wobbling coil to the specified place on CRT neck.10. Put on landing sensor to CRT face.
This Toll has many optional accessories for various newer LCD and Plasma Models, however it is offered here
2 - Data cable Connects Trace tool to TV under Test
3 - Optional Infrared Remote control Repeater ( Can be used to remote Program TVs )
4 - Trace Software + Infrared Repeater Software + Instructions sheet
Tool Needs a Serial Communications Cable ( NOT a Standard Modem Cable )
Self Test (OSD Color Bar): During Power Save, push up UP button for longer than 2 second.DELL P1130 CHASSIS SONY CR1
Runs on an Internal 9V Battery
https://elektrotanya.com/sony_gdm-f5...wnload.html#dl
Optionally can be powered by a 9VDC Power pack
hi
i am
Visual
