LM317s IIRC can have a minimum regulation drop 1.35V...so for example if your rectifier outputs 7V you can only get 0-5.65V out of it and have regulation. You could use a voltage doubler rectification circuit to get around 12V and circumvent that min voltage drop of the LM317.
problem is always with a voltage doubler is stable current with unknown current loads , granted, the regulator could stabilize it. i played with it some more on a variac , I found that bringing up the input voltage from 120(ish) to 129 raised the heater voltage to 7.1 volts and made a VERY noticeable improvement on the screen. so i did a bit of digging and found a 12 volt 3 amp DC power brick. so I will take that, a LM317T,a 5W 8.7V Zener Diode as a crowbar, and a 1 amp mini fuse. and set it to 7 volts or so, I should never reach the 8.7 threshold, so the Zener Diode should never clamp and blow the fuse,
