Most Sony manuals have the consumer manuals in them.
Using that be sure all the tuner setting are for normal VHF/UHF band & normal AFC ( AFT ). That will eliminate that. The fact that only some work through composite inputs is troubling. It may point to an actual problem so listen carefully ! You can go into the service menu & check for some thing thats off. MUST DO is write down ALL the setting before ANYTHING is changed. When you exit the menu be SURE to do it right & by the book. You will probably need the OEM remote to do it. 73 Zeno ![]() LFOD ! |
