Old 08-14-2021, 11:16 AM
I got lost in the dialogue!
What transformer is damaged? The one in the GE A83 or the one in the Philco?
The transformer in the GE is bad, and I want to see if the transformer in the Philco will be a suitable replacement or not.
Old 08-14-2021, 11:33 AM
I checked the schematic and the power transformer looks close!
The B+ might be a little high!
Tag the leads when disconnecting from the original chassis, as the Philco colors might be different.
Old 08-14-2021, 02:50 PM
I'm also concerned about the fact that the Philco uses the old style tubes vs. the GE using the Octal style tubes, would that make a difference?
Old 08-14-2021, 03:22 PM
The tubes are identical, except the base. Same heater current and voltage.
Philco didn't switch to octal base tubes until the '37 model year.
Old 08-14-2021, 07:24 PM
OK, so then the power transformer should be able to swap out for each other, the only other issue I could see being a problem is the mounting screw hole spacing for the power transformer from the Philco radio vs. the the GE's original Power Transformer.
Old 08-14-2021, 08:26 PM
You might have to drill different holes to match the footprint of the replacement transformer. The original transformer is mounted a little different, with long through bolts, so it sits above the chassis.
Old 08-24-2021, 08:17 PM
Well a little update, apparently the power transformer wasn't the problem, it was the power switch on the volume control I subbed in, apparently the power switch was bad...? because I put the original volume control and power switch back into the radio last night and the radio popped right on as soon as I powered it on... Weird, I didn't know those power switches could go bad like that.
Unfortunately that persistant and untraceable hum is still there and I still cannot figure out where its coming from.
