Telefunken Gavotte 7
Hello everyone, earlier today I picked up from a local guy who used to be an employee of Crown here in Elkhart before they went belly up, a 1956 Telefunken Gavotte 7 AM/FM/SW/LW Hi-Fi radio that he said still works but has filter capacitor hum.
I would like to know how hard it is to replace the old filter caps in these old Telefunkens and how good of a performer will this radio be once its recapped? Also where did this radio fall in the model heirarchy? Thanks for your help with this radio. |
I own one. It's a monophonic unit. These are loud and sound superb when working properly. Decades ago it was restored by the tech that got me started learning radio (he bought it to fix and flip and I ended up buying it) so I can't tell you how hard it is to recap.
These radios almost always have the schematic in an envelope inside the back.
I don't have a scanner and most people find my pictures illegible...This is covered in Sam's so you should be able to find a Sam's for it.
There's even enough room in the chassis to tack a terminal strip in there and wire in a couple of 47 MFD 450 V axial lead caps to replace the old filter cap can. |
Is there a current source for a replacement pilot light socket for this radio?
I'm asking because the pilot light socket on mine is trashed, the rubber insulator/mount is completely dry rotted and I was thinking of reinforcing it with shrink tubing around the socket itself but then the rubber mount broke...
I have a couple of Telefunkens in daily use. They are pretty easy to replace the electrolytics. One had a selenium rectifier that was getting too warm. The other was fine. I replaced both with silicon diodes and put a dropping resistor in there. They are great performers. On of mine is a Gavotte and the electrostatic speakers don't work and I haven't gotten around to trying to fix them. The set sounds good anyway. In short, I love the styling and performance of mine and have many hours on them.
working German radio in my collection. How did you fix the light socket in your Gavotte? |
Hmm, well mine is presumably still working but the rubber insulation around it failed (it dry-rotted) and I'm not sure how that happened.
I'm assuming it had to do with storage conditions, as the guy I got it from originally had the radio stored in an old storage locker that wasn't climate controlled, because he lives in an apartment building that dates back to the early 20th century and I don't think he had access to the basement from his apartment but I could be wrong. Anyways I would think that one could use shrink tubing to replace the old rubber insulation around the light socket on this radio, but I'm not sure. |
Hi!
Do you want a clean manual incl. dial stringing? I have closeby everything in schematics, but I am hanging here around only in the TV sections. ![]() Just saw your request. You can have from me SABA-Automatic repair informations, too, in english! Just send me your email adress and what else you need. Regards, TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany! |
Yes, some heat shrink should be fine. I haven't really looked at the wiring of mine since it is working. But if it is easier to heat shrink than replace then do that.
Yes, I think Heatshrink tubing would work better than trying to locate a new light socket for this radio which is a style of light socket that I have yet to see on places like Mouser, or Digikey.
![]() I looked it up in the dictionary! I have a few German sets. The selector switches are crumbling from using the wrong contact cleaner. |
I believe that Telefunken named all of their radios, stereos, hi-fi sets etc. after musical terms. I figured out what was going on with my radio, its a combination of dirty switch contacts, and weak tubes, the tube that was the most responsible for the poor reception/performance was the ECH81 which I unfortunately don't have a spare of.
