Old 09-09-2021, 05:26 PM
madlabs madlabs is offline
@old_coot88 I think you nailed it. I dug up one of my parts chassis and the inductor reads as it should, 139 out of 140 ohms. So the one on my set is indeed bad.
So, the next question is: Are there other issues that could have caused the inductor to go bad that I should check for? Or is it just a luck of the draw thing?
Old 09-09-2021, 06:04 PM
lt's generally a luck o the draw thing unless there was an overcurrent condition that made the coil go open. Check that 15K 1 watt plate resistor (R62) that's in series with L22. Does it look charred by any chance?
Old 09-10-2021, 12:36 PM
For what it's worth your L22(Philco 32-4754-3) crosses to Thordarson HS-16.
https://www.ebay.com/itm/23403929297...IAAOSwy9pguZCy
Old 09-10-2021, 03:24 PM
Wow. You guys are awesome. I am going to try running the set with the coil shorted out. Last night the contrast and everything was out of whack from pulling the knobs off and pulling the chassis out. So I will see how well it runs as is. I did pull one of the dead coils from my parts board and it appears the open is inside. I may try peeling some wire off to see if I can find it. But if it runs ok as is I will go with "if it ain't broke, don't fix it". Because every time you perform surgery there is a chance of screwing something else up.
Again, wow! Thanks for not only looking up the cross reference but linking the part for sale on ebay! I couldn't click but it now fast enough!
Now, back to some tile work. Flipping real life is such a pain. But I will fool with the set again later.
Thanks! I really, truly mean that.
Old 09-10-2021, 04:12 PM
If you can find the break in that coil, there's a neat method of stripping hair-fine wire without mechanically abrading it, called the 'aspirin trick'. No lie, it really works. Put an aspirin tablet on something like a jar lid. Use a soldering iron (or gun) to heat the aspirin so it forms a puddle. Dip the end of the wire in it, and the hot acetacylic acid strips it clean. The fumes are gawdawful, so use plenty of ventilation.
Old 09-10-2021, 04:15 PM
oddly enough
that is exactly the same part that they are selling in the link I posted above from Talon!
Item #
COIL152
Other Part Numbers
GE WT36X402 RCA 111380
and they have 3!
not so hard to find after all!
Old 09-10-2021, 06:10 PM
oddly enough
Item #
COIL152
Other Part Numbers
and they have 3!
I guess not! And thanks for the link. This really is the place for old TV's.
