Old 12-08-2021, 01:32 AM
I'm well aware B+ feeds multiple circuits. Are you saying you are measuring a negative voltage at point TS8-3 where you have circled, or everything to the right of that point including all the audio output voltages? C50 is an audio coupling cap and has absolutely no influence on B+, other than it could be leaky and letting B+ cross over to the volume control. If that cap is bothering you please remove it from the circuit.
I'm measuring a negative voltage at point TS8-3 and everything to the right of that in the TV's Audio Circuit, everything to the left of that measures normally (or as normally as a still malfunctioning TV can measure) which is the 210V that is supposed to be the 245V B+ Supply which is currently only measuring 210V right now.
