Old 12-19-2021, 10:56 PM
BandDirector
Guest
Posts: n/a
6BK4 B vs 6BK4, nevermind!
Adding a new tube, a 6BK4 in place of a 6BK4 B created more brightness in my ctc 17x ad, and some bluish glows in old tubes and some popping/clicking sounds (it hasn't made any sounds up to this point). It is a HV regulator, so is the set getting more volts? As in perhaps closer to the 24kv it needs? And older tubes glow more?
Are these interchangable?
Not interchangable, need 6EL4 or similar
Old 12-20-2021, 01:05 AM
You really need an HV meter if you are going to work on the HV regulator of a color set. HV is supposed to be set based on HV voltage measurement or in some cases off the HV reg cathode current.
If the HV is say 3-4KV above spec now, the flyback could start to arc internally, form an internal carbon track and fail.
Old 12-20-2021, 07:36 AM
BandDirector
Guest
Posts: n/a
Check
