If you want to help people document everything. Rare stuff like this odds are nobody else is working on now, but someone will find one x months from now and then have tons of questions.
small update of progress. Was able to get a broken diversity unit. Repaired it and found a cable with similar connectors that didn't take too much effort to modify. the tv functions came to life. Not able to get the composite video-in signal to stablize (or colorize) yet. But almost there.
![]() 1-15-2023, after checking packages, I now have 6 XAV-u50 indextron, 1 xav-55n indextron, and 1 xav-u51 indextron. 6 diversty units (also labeled xav-u50 ¿?). 2 original cables, 1 non original made to work. Last edited by HelloVoltage; 01-15-2023 at 05:30 PM. Reason: extra overlooked info. |
Well done
I have 2 x Sony Indextron TVs that I still need to send to Andy in USA |
if you mean watchcubes, have 9 working for a wall (3x3 array) project, can also possibly repair for you. If one of yours is white, would trade straight for a working black or working blue.
the composite cable in post 170 of this thread should be disregarded. I used it in ignorance. The port into which it is inserted is much more complex, hence the thread I started here: http://www.videokarma.org/showthread.php?t=274650
Mine are blue and black
expected. That white is a rare beast.
Hi to all,
Hi HelloVoltage, Nice screen displays in your post #178, Congratulations! on getting it working. What a collection of Indextrons! i'm impressed. If you have time, it would be useful to know about the differences between the different XAV versions (50, 51...). I have a XAV-U50, display unit only. Never powered it up as have no data on the multipin connector at the rear of unit. Would you have identification of the pins or a schematic of the connection cable? Guess it goes to the Diversity unit which i don't have. Am hoping the display unit could be fed composite NTSC or RGB or VGA, whatever Sony decided to use. Thanks! for any tips, Best Regards jhalphen Paris/France |
