Old 02-14-2022, 08:43 PM
C5 and C6 appear to be backwards
Old 02-14-2022, 08:54 PM
Ah. I was looking at Riders, which has those correct.
At any rate I think Bob found the smoking gun in an unsuspected area.
Old 02-14-2022, 08:56 PM
always where you least suspect
Old 02-14-2022, 09:24 PM
Yeah, this felt like an HK short issue all along. The one tube I never thought to test was the CRT
Old 02-14-2022, 09:31 PM
[url=https://flic.kr/p/2n3GguK]
OUCH!
finding another 7JP4 will be impossible.
risk trying to burn it clean or, use a separate transformer for it?
Old 02-14-2022, 09:36 PM
OUCH!
Bob's in Chicago within driving distance of me in Milwaukee...And I do have a spare good 7JP4...(heck I have the three amigos of 40s CRTs 7JP4, 10BP4, and 12LP4 sitting in my spare pile.)
Old 02-15-2022, 12:27 PM
That tube tester's veracity is questionable regarding an HK short in the CRT. If there were a heater-to-cathode short, it would kill the video signal going into the CRT as well as show a heavy hum bar (since the heater is 6 VAC away from ground, thru the 6X5's heater). In a case like this, the TV itself should be the best "tester" of the CRT.
Old 02-15-2022, 01:45 PM
You are correct. I had both F2 and K set to pin 2
So back to the drawing board. The tuner filament transformer and filter choke seem likely candidates. I could power the tuner with a separate 6 volt source.
