I did find a service manual for this VCR (its the Sam's version.)
I found the correct page for the Motor Drive Circuitry, hopefully that will help others follow along.
OK, so I looked at the Service Data and it looks like IC2007 is the one that controls the motor control board and was the one you were talking about possibly being bad am I correct?
It's possible but without doing some testing with a service manual, scope and DVM don't get me to lying!
Since I now have my 'scope figured out how to work it I'll see if I can figure out what's what on the VCR. |
Be sure to check for a shorted electrolytic capacitor somewhere in that motor drive circuit too, could be something as simple as that. As old as it is that's a possibility.
One in particular looked kind of out of place (it looked a little newer than the rest of the capacitors in the unit and also it was a higher capacitance rating than what's called out in the Sam's), which is C30 (C2530) which is supposed to be a 100 µF 16V but instead had a 470 µF 16V capacitor in that spot, which unless there was some sort of design change made to the unit that wasn't reflected in the Sam's (or that was reflected in the Sam's) I think someone installed the wrong size capacitor in there, which I'm apted to think that someone put the wrong size capacitor in there because as I said the capacitor was a completely different style of capacitor than the rest of the capacitors in there. |
If I had that machine first thing I would be doing is checking every electrolytic in it with my ESR meter. I actually have two, one I used at the shop and the other for home use, it's that important and useful. Last edited by Ed in Tx; 05-21-2022 at 10:39 AM. |
PV-8000 motor drive schematic 1.jpg PV-8000 motor drive schematic 2.jpg EDIT: Because the resolution of the attachments is garbage, here's the links for the full-res png files: https://drive.google.com/file/d/1Xge...ew?usp=sharing https://drive.google.com/file/d/1LGu...ew?usp=sharing Last edited by djfivos; 05-28-2022 at 09:33 AM. |
