Old 06-03-2022, 05:33 PM
Dave A's Avatar
Dave A Dave A is offline
RCA 19" portable
What do I have here? The model tag is gone and I need the Sams. Educated guesses will do for now. I'm not ready to open the set to find the chassis #. The pic is a bit better than the CRT really shows. My dad bought it in the early 70's to have a second set for a Super Bowl party. The main set for the party was his late mothers CTC9.
I have never recapped it. It's running on the originals or service replacements. No hint of hum problems. I've had it 20 years and it fired up after 5 years or so under cover. Just tired needing tubes, a convergence, and a Beltron bump. It's running on my OTA ch 7 modulator. I want to get my Beltron back from repair before I try anything. It will be a tubetestfest to start.
Old 06-03-2022, 08:24 PM
It's possibly a CTC53. You should be able to see if it has a solid state IF strip.
It's probably best to remove the back and locate the chassis number. You don't want to spend the money for a Sams and find out you ordered the wrong one.
Old 06-03-2022, 08:28 PM
damen's Avatar
damen damen is offline
RCA used that style for several model years. Could be a CTC-36, CTC-43, or CTC-53. Once inside, there may be another model/serial number sticker glued to the chassis.
Old 06-04-2022, 10:51 AM
Many of those models had the low voltage focus CRT's. When they got older you couldn't get proper focus no matter where you moved the focus jumper. Many VK members mentioned that a mild rejuvenation improves the focusing.
Old 06-04-2022, 01:18 PM
Yup find the CTC-## usually inked on chassis.
Some have the model ## on the bottom.
Also remember some had tags around the HV area.
And have a load of 'GH8' s ready !
Old 06-04-2022, 03:02 PM
I'm curious, Zeno -- what was it about the CTC-19 RCA TVs that made them go through 6GH8 tubes so quickly? RCA, after all, was a pioneer in electronic television. I cannot believe they would even consider designing a TV, or any television they made in the '80s onward, for that matter, which would push tubes to their limits, and often beyond. Something must have happened to or with RCA in the last few years to cause their design team to cut corners like this.
Old 06-04-2022, 04:16 PM
Jeff OM
My theory is heat & sockets. All the plastic 14" & 18-19" had a great apatite
for low level tubes especially 5GH8 & 6GH8. Noisy sockets led to good
tubes getting changed & fixing things for a while. GH8's would be bad BUT work fine in another function. The trick was getting the set "fixed" good enuf
but not loading it up with tubes.. Challenging.!
Maybe tomorrow I will comment more on the subject, kinda tired after
much yard work today.
Old 06-05-2022, 11:28 PM
Jon1967us Jon1967us is offline
I have a CTC-53 that looks exactly like it.
Old 06-06-2022, 04:07 AM
Retired Batwings Tech
CTC22 had that exact set years ago
Old 06-06-2022, 01:37 PM
Sure looks like a 22, but the OP says 19 inch... the 22 I had was only a 15”.
Old 06-06-2022, 03:20 PM
Yeah, the 22 was a one-off design and used a ss damper diode that was very problematic.
Old 06-06-2022, 08:30 PM
damen's Avatar
The CTC-43 also used that damper diode
Old 06-07-2022, 02:50 AM
Was sure it was a CTC22 but I'll stand corrected.
Old 06-07-2022, 10:17 AM
I had a CTC22 and it had a damper diode, that failed. The RCA replacement was two of the same diodes strapped together. It also had some kind of a HV regulator tube.
I had the set for about a year and then sold it. Before I sold it, I tested all the tubes and found three 5GH8's weak. Replaced them and sent it on it's way.
The 19" model CTC36 was similar, but used a damper tube.
Old 06-08-2022, 11:55 PM
Guess they got a clue with the diode
