Old 06-18-2022, 08:10 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Originally Posted by vortalexfan View Post
I think it should be able to be repaired using the Shango method.
Shango method... awaiting the results.
Used to get in PV-5000s and PV-6000s (portables) with cracked 3-layer boards a lot. Panny had placed a small rubber spacer between the board and the bottom cabinet panel. All it took was a bump while carrying it around to crack the board. Yes I repaired them, charged by the hour. Used the Ed method.
Have fun!
Old 06-19-2022, 11:21 AM
Have fun!
I meant Shango066 on YouTube. 😜
Old 06-19-2022, 12:03 PM
Ed in Tx's Avatar
ah.. OK. I thought you were going to listen to Santana's "Shango" while you worked on it. That was one of several albums I used to listen to while at work.
Old 06-19-2022, 12:11 PM
That's OK, I just thought that when one mentioned Shango on here it was kind of understood that one was talking about Shango066 on YouTube.
I guess I shouldn't assume things like that on here. 😅
Old 06-30-2022, 03:02 AM
OK, so I finally got the VCR Fixed!
But of course now it has a timing issue related to the mode switch I think, because when I put the tape in, it loads the tape in normally like it would if you tried to play a tape but then when you hit play the tape loads against the heads and attempts to play but then unloads the tape back into the tape housing, and if I try to hit rewind or fast forward the tape will rewind for about a second before stopping and then loading the tape against the heads like its going to try and play but then the VCR shuts down and when you try to power it on again it shuts back down again after a few seconds (and the tape is stuck in fully loaded/playback mode the entire time.)
Is there some sort of way to figure out which mode the mode switch is in in reference to the mechanism? Like is there some sort of specific marking that will tell you which position is which on the mode switch (ie stop, play, Rew, FF, Eject, Pause, etc.?)
