Old 06-26-2022, 10:10 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Originally Posted by YamahaFreak View Post
Can I just test components in-circuit with my meter to find the short? Where would be the most likely culprit? (Transistor, capacitor, resistor, etc.)
Yes. Any of those you mentioned.
Repeat tip: NEVER apply unlimited power to a failed SMPS always use a series incandescent light bulb, I recommend 40W in this case, when first testing it out.
You'll probably find the drive transistor shorted, cannot tell from your pic either a shadow or blackened circuit board in that area. May find a protection Zener diode on the secondary side, maybe a shorted diode or two, too. Don't take that as gospel! I said "probably", as in might, may...
And check all capacitors for ESR. Replace those with higher than normal resistance.
my 2˘.
