Sony Trinitron Fan |
Under normal conditions there shouldn't be enough heat to discolor the board. Might happen though if one or more capacitors mostly on the secondary side were failing. Sometimes that can make things run hot until they fail.
Did some preliminary testing. In the attached image, the circled diodes test shorted (same readings both ways) and the one circled resistor is open. I haven't looked up how to test caps and transistors with my meter yet.
I'd assume a totally shorted rectifier is a pretty bad thing, hopefully the whole unit isn't toast.
The diode though, and Q901 and Q902 I would be suspicious of. And anything else in that cooked area. It's been getting way too hot there. You need an ESR meter to test all the caps. If you plan on doing this sort of thing as a hobby (or a living☺) you need to get one, not just to fix this machine. Said it before: Electrolytic capacitors are the bane of electronics! And yes if those 4 diodes that make the full-wave AC rectifier are all shorted it probably took a nasty power surge or lightning hit. |
I will add to Eds comments.
First watch a few SMPS U-tubes & and get to know how they work. Pick simple ones. There are some real monsters !! There are several styles so pay attn to the block diagrams. Blown fuse is usually the power FET, the bridge or MOV if it has one. If the bridge is bad change ALL FOUR at once. If the FET is shorted you need to find why. Usually lightning but other possabilities. Often boils down to gambling an FET or not. On yours the burned area is VERY suspicous 73 Zeno ![]() LFOD ! |
FET? Actually it looks like a 2SC4418 or 4419 (can't quite tell from the picture) Silicon NPN high speed power transistor. Pretty common. Have seen those lose gain and not work but still test good with a multimeter.
