If the CRT tested good, you have good HV and the CRT socket voltages are OK then there is only one other thing that I can think of, the ion trap.
Could you have moved it? If it is the electromagnet type, is it passing the correct current? Any sound from the speaker? |
Ion trap was my first thought.
Hi there...thank you so much for responding! So, I'm at work and can't check this but, there's a ion trap magnetic coil that is supposed to have 17.5v DC running through it. I'll check the voltage and continuity tonight. I think I ohmed that out as well. It has 2 coils, 33 ohms and 3 ohms. Since it's electrified, do you think it's an electromagnet and not a passive magnet that in a set this old, would have lost its magnetic qualities?
Nothing from the speaker
