Old 07-05-2022, 03:13 PM
He knows. He was posing it as an example of what happens when you don't have a filter cap.
The outer coating of the CRT should be ground. It allows the CRT itself to act as a filter capacitor for the high voltage.
Old 07-05-2022, 07:30 PM
Originally Posted by Chris K View Post
Hi Tom...would something like this work? I do have an HDMI output port from my computer.
https://www.amazon.com/HDMI-Converte.../dp/B07W58PNPP
I bought one of those to try a while ago. I can't recommend it because the one I got would regularly black out and come back to normal. Maybe I got a rare defective unit, but if a good portion are like mine (likely for no-name Chinese stuff) it's not a great gamble.
Also IIRC the ad claims it will transmit...It doesn't seem to have the power for anything other than a direct connection and even then was going dark regularly.
Old 07-06-2022, 06:00 AM
Chris K Chris K is offline
Hey there...thanks so much for chiming in. I've been watching your restore on this unit over and over. Yes, the graphite coating on the CRT contacts 2 wire loops on the yoke frame when the CRT is pushed all the way in. I'm not going to obsess over the HV reading. The picture is OK at this point and I'm going to turn my attention to getting some sound.
I've been working backwards from the speaker in the troubleshooting. Speaker pops and moves on contact with a 9v battery. AOTrans ohms out ok and there's continuity all the way back to the AOTube sockets but that's where it gets dicey. Filament voltages are OK and the tube is new but there's all sorts of out of spec voltages on the other pins. I was going to get a read on them last night and post but I never got off the couch and YouTube all night!!!
Old 07-06-2022, 06:29 AM
OK I guess I'll stay away for now and rely on the pattern/sound generator and the crappy over the airways digital, converted to analog, signals. On these projects, I try to maintain a conservative, step by step diagnostic and analysis approach but sometimes, at a point of "problem solved!", I want to race to the end game finish line ASAP. I need to concentrate on getting sound next.
Old 07-06-2022, 09:08 AM
Notimetolooz's Avatar
That HV meter looks OK. I haven't seen that model before. Yeah, it could be the capacitor smoothing effect.
A quick and dirty way to check the audio output circuit is to touch the wiper on the volume control with a screwdriver with a finger touching the blade. Don't have the volume control turned down however. You should hear a hum. If this was a hot chassis set you definitely want it plugged into an isolation transformer to do this.
You would need a FM modulated 4.5MHz audio signal to inject to trace the signal further up (from the volume control towards the tuner).
A oscilloscope could enable you to trace the audio from the tuner toward the volume control.
Without those you are left with checking voltages, resistors and tubes, etc.
Old 07-06-2022, 10:04 AM
I'll check the HV with the CRT in place, grounded and plugged in. I managed, after a 6 month wait, to get my hands on some Aquadag graphite with binder spray from Ted Pella Associates and I can spray any chipped or scratched areas although the coating on this CRT is pretty complete and undamaged.
I do have a scope and a signal generator. I can give those a try. Maybe Mr. Andersen would know if this is a hot chassis but I do have the hot and neutral blades of the power cord marked so I can be sure it acts as a keyed plug.
On the topic of the power cord, it's in terrific condition. Is there anything I can do or a treatment I can apply to help preserve the rubber and keep it from becoming hard and brittle?
Thanks
Old 07-06-2022, 01:08 PM
It is not a hot chassis. I believe the original cord would by vinyl not rubber.
BTW less expensive and more readily available Slip Plate graphite coating works well on CRTs.
Old 07-06-2022, 01:15 PM
[QUOTE=bandersen;3242720]It is not a hot chassis. I believe the original cord would by vinyl not rubber.
BTW less expensive and more readily available Slip Plate graphite coating works well on CRTs.[/QUOTE
Great...one less shock hazard! I'll google SP and check price and availability. I've got a Zenith and a Philco Seventeener where the dag is flaking off in big chunks!
Old 07-06-2022, 01:40 PM
This is a early post war split sound set so the sound IF is 21.25MHz NOT 4.5MHz that intercarrier sound sets use.
Also he may be able to get away with a tube AM modulated signal generator...Most tube TV/radio repair grade generators distort the the RF carrier enough to create FM/PM modulation that TV audio systems can detect. I've done this with 2-3 different generators so far.
Old 07-06-2022, 01:57 PM
I have an old Knight Model KG-650 RF generator with an output range from 100 kilocycles to 100 megacycles. We might be getting into territory here where my comprehension database is running full throttle and losing ground!
Old 07-06-2022, 02:12 PM
If it's a working generator odds are it will work for audio IF signal injection...IIRC a friend of mine has the same generator and has used it for FM work. You can check it by using an FM radio set to a dead channel in the 88-95MHz range and trying to tune the generator to make a signal in that range. If the FM radio tunes it then there should be enough FM slop in the generator for it to work with TV audio.
Before you start with IF injection first try audio injection at the first audio stage grid. That knight generator should have an audio output you can use. If the set passes audio from the 1st audio grid decently then IF injection is the next troubleshooting step. If it doesn't pass audio injected at the 1st audio grid then troubleshoot the audio stages and make them work before messing with the audio IF.
We can walk you through audio IF injection if you end up needing to do it.
Old 07-06-2022, 02:15 PM
I get what EM is saying, that most tube frequency generators ( like my Eico324) and so on, will have just enough intermodulation / distortion in them to trigger the sound discriminator circuit in the TV when you feed the generator via input AM modulation.
IE, you should hear some pretty weird stuff when you get it right!
Old 07-06-2022, 02:21 PM
Excellent...I have a Channel Master Super Fringe (Sanyo inside I think) AM/FM I restored that has a great speaker and makes terrific sound for a 1962 tube set. I'll try using that and the Knight. Yes, I will probably need some seeing eye dog aid in crossing these audio output tracing streets! Thank you so much for the help. It is so appreciated as is everyone's input in this thread. Thank you all!
Old 07-06-2022, 05:47 PM
So my RF generator is set at 21.25MHz. The grid on the 1st audio tube, 6AT6, is pin 1. Do I need to ground the black generator output lead or just touch pin 1 of the 6AT6 with the red lead from the Knight? Sorry for the very basic questions here but this is virgin soil for me!
Old 07-06-2022, 05:48 PM
Nice loud tone on the FM radio BTW from the Knight
