Old 07-06-2022, 08:34 PM
Chris K Chris K is offline
pins 8 & 7 are tied to gnd so they are 0v , pin 2 is heater at 6.3v AC, pin 4 (ctrol grid) is tied to bias & the red wire of the output via 1k resistor to +225, should be about 200v, pin 3 is hooked to pin 3, plate and will be lower because of the 500 ohms of the output @ 185v, or so they say.
pin 5 is pulled negative via 470k
Learning so much here...thank you very much. I'll get to work!
