Old 07-18-2022, 10:30 AM
When the high voltage rectifier winding arced through, I used to cut out the wire and used an EDI solid-tube which was a solid-state replacement for a 3A3/3DB3 or a 3AT2, depending on the set. It was especially important on a Zenith that used resistance wire for the winding.
RCA's seldom needed it because the flyback was replaced before.
thought about that, but when I tried the Philips ECG ECG508 / R-3A3 45KV Silicon Rectifier in my CTC-16XL, it self destructed in 90 seconds for some reason.
bit worried about trying one again.
Old 07-18-2022, 10:47 AM
...I tried the Philips ECG ECG508 / R-3A3 45KV Silicon Rectifier in my CTC-16XL, it self destructed in 90 seconds for some reason.
Are those actually silicon? I always suspected they were a selenium stack, and never trusted them.
Old 07-18-2022, 11:04 AM
shango066 also tried one in a roindie, and it fried in 20 min.
so I tend not to trust them.
if anything SS, perhaps this or something like it.
http://hvstuff.com/40kv-1a-high-volt...fier-tesla-ham
Old 07-18-2022, 11:17 AM
I never had one fail, so I don't know if they had a string of silicons or selenium stack. If I knew they were selenium, I never would have used them, knowing that the focus rectifiers were.
I used the EDI brand, not the ECG.
Old 07-18-2022, 11:59 AM
i did a quick look, but sadly any compatible EDI brands are quite unobtainium.
So the choices fixing it to the original spec, which I will try first, then go with that huge 1A 40kv SS diode later if all else fails.
Old 07-18-2022, 01:41 PM
Turns out that site with the 40kv ss diode is fake, the entire site is nothing but a rip-off.
However, I did find a EDI Solid-Tube R-3DS3 7541 on eBay, a 3DS3 is not compatible, but as a last resort, the SS R-3DS3 can be made to work, as it's well within spec.
Old 07-18-2022, 03:02 PM
dtvmcdonald's Avatar
Or as an old Zenith engineer once said when shown the first RCA experimental color TVs, "27 controls, each one making it worse!"
There are 82 adjustments on a CT-100. This includes only one channel strip. It includes the six position and tilt adjustments of the yoke, which are
all very criticasl for perfect convergence.
I adjusted every one on my TV, and they all DID make it better! (except the RF on the strips, which were OK.).
In fact I added an 83rd one, one additional adjustment in the color matrix ..
and that really did get it better, even after changing all the fixed resistors to 1% ones.
Old 07-18-2022, 07:09 PM
EDI Solid-Tube R-3DS3 7541 ordered
HV wire will be here tomorrow, FBT coated VERY well with dope and cured, and ready for new wire, I doubt it can arc any more.
one way or another it WILL work.
Old 07-18-2022, 09:28 PM
John Adams's Avatar
John Adams John Adams is offline
Here is the link to what could be a useful site to check out a website.
My search was for kalesafe.com and you can see the results. There is a search feature at the top. https://www.scam-detector.com/valida...fe-com-review/
2 Working Zeniths and one on the bench. Into electronics since the days of Earl "Madman" Muntz..Worked 8 years for a Zenith dealer in NW Arkansas.
Old 07-19-2022, 08:20 AM
As Tom Petty once said, “the waiting is the hardest part”
Amazon SHOULD bring the new HV wire today, with which I hope to re-wind the newly doped FBT and try again with the 3A3C.
Did a resistance check on it.
http://suzaku.live-evil.org/fbt112.jpg
It all mostly agreed with what SAMS says except fot the one 4.7 ohm reading which was about 10, but I have seen this before, where what they had listed did not match real time with what was in the sets and there was nothing wrong.
Especially when there are 2 different FBTs listed in the SAMS, Hoffman # 033-013000 & 033-012700
both replaced by merit hvo-234c / stancor ho-601c / triad d-304.
And if worst comes to worst and this CRT is no good, ETF does have at least 1 or more that will fit in this thing, :O
Old 07-19-2022, 09:44 AM
The only Hoffman set I worked on, a 23" CTC15 clone. The flyback Sams specified was the wrong one. It was for a 70deg round tube set. It didn't work properly!
A friend worked for a Muntz dealer, so I ordered a flyback from him. Worked great and it was a lot cheaper!
That was about 50 years ago.
Old 07-19-2022, 02:40 PM
OK...
this just got a bit stranger.
the replacement FBTs listed in SAMS are FOR the RCA CTC-15 .
was the same one used in the 17?
this is odd
its not SAMS that makes the subs, but merit/stancor/triad right?
Old 07-19-2022, 03:09 PM
The CTC-15 was a roundy the CTC-17 was a rectangular...The deflection angles are different between the two so RCA definitely used different flybacks in the 2 chassis, and I have a hard time buying that Hoffman could have made a roundy fly work in a rectangular set.
Old 07-19-2022, 03:16 PM
Then the list in SAMS must be wrong, just as DJ ran into 50 years ago!
Old 07-19-2022, 08:18 PM
The Sams was wrong!
