Old 08-02-2022, 11:38 AM
kf4rca kf4rca is offline
What standard does it use? Line and frame rate?
Is it PAL? Is it AM or FM sound?
You could use individual resistors for the tapped resistor if you have enough space.
There was once an American model called FADA which was the initials of a man's name.
Why only one channel? I once worked for a station and the general manager said he often dreamed of a cable system with only one channel- HIS!
Old 08-02-2022, 09:18 PM
Penthode's Avatar
Penthode Penthode is offline
PAL was not introduced until 1967. Polish analog tv was system B 625 line 25fps interlaced with a 5.5MHz video-sound,carrier spacing. Essentially the same as the rest of Westen Europe.
One channel is practical for two reasons, saving the cost of a complex tuner and ensuring the audience is properly propagandists by control of the media.
The earliest British TV sets were one channel as there was only the BBC Alexandria Palace transmitter until 1949 when the West Midlands transmitter at Sutton Coldfield began
