So keep in mind that the usual power, voltage, and current calculations only work for DC current or sinusoidal AC current (with RMS value for the sine wave). Once you go to pulsing current in a rectifier circuit, things are quite different! The instantaneous power, voltage, and current still follow the usual relationship, but the relationship between instantaneous current and average current is no longer so simple. |
I have left the trio of 1.5 ohm 11W resistors in series with the silicon diode rectifiers I installed and they are pretty hot. I loomed at the Ohmite recommendations and the temperature is well within the range Ohmite specifies. And the B plus voltages are near correct. I will leave as us for now. |
Saturday afternoon made the input block attached to the KRK12C tuner using the dimensions from the CT-100 manual. The RF sweep signal is applied to the mixer diode in the tuner and using and alligator clip there is awkward. The input block position is reinforced with a sprung clamp around a transformer can a well as the two phenolic pins with straddle two holes on top of the tuner.
This will be used to perform the IF alignment and chroma channel as well as facilitating full sweep tests as outlined in the RCA Service manual. Now on to the testing and alignment this week. |
Wish they did something similar for the CTC-5. That connection is so sensitive to lead length/dress.
I immediately searched EBay for a replacement part or even generator for parts and found a brilliant and enterprising engineer redesigned the 8601a output amplifier module and offered them for sale. I bought one and the 8601a now has a flatter output response than the original amplifier. Had to be patient on the CTC5 waiting to fix first the HP generator but it was worth it. I am grateful fortunate that gains do often come after adversity. The photo below shows the contact spring against stage mixer diode pin. Last edited by Penthode; 08-14-2022 at 11:25 AM. |
Decided to postpone the chassis alignment and bandpass evaluation while I fixed and refinish the cabinet. Peeling veneer relied and front mortised corners were separating. Glued with lot of long clamps all around to pull it back together.
Cabinet was badly banged up. Hoped not to have to do much sanding but had to fix many deep gouges. Stained to match original finish. Came out very close to the finish removed. Two spray coats of Watco lacquer on the main cabinet to be lightly flattened and polished. Still to do lid and front wood control panel cover. Seems to be a province wide shortage of lacquer products in Ontario at the moment. Found a hardware store 30 miles away had two litre tins which I collected on the weekend. Last edited by Penthode; 08-30-2022 at 07:26 AM. |
