That all sounds correct. Do you have another 12AU7 to try in circuit?
I have a couple of NOS 12AU7s. I'll try them
Makes me wonder if it's suppose to go negative with no video signal from the detector. I need to go look at the conditions for the voltage readings.
The only note I see is that voltage readings were taken with the picture control fully counterclockwise. Without a scope it's hard to say what type of signal you're measuring with your(I assume) digital voltmeter.
You can try tying pin 7(grid) of V105 directly to pin 8(cathode). With the cathode and grid both at the same -85v it should cut-off the tube from conducting current and allow pin 6 (plate) to go positive. With the grid at -85 and -84 on the cathode it should be cut-off with no IF signal present. Check R120, R121 for correct resistance. Something needs to give.
