Old 08-23-2022, 10:53 AM
I would say it's a minor nuisance to do the subtraction or addition of 455 kHz, so just go for it.
A signal generator is equivalent to the local oscillator part of the tuner. The tuner also contains (at least) a "mixer" stage. The mixer multiplies the oscillator wave with the signal wave, converting the signal wave to IF frequency. In the usual AM radio, the local oscillator is tuned by the dial to a frequency that is above the desired signal frequency by 455 kHz, so the signal is converted to 455 kHz range for the IF to amplify.
For a very thorough discussion when you have the time, see wikipedia: https://en.wikipedia.org/wiki/Superh...er%20frequency.
Old 08-25-2022, 11:13 AM
I have a Zenith Royal 2000-1 that has a tuner output RCA jack on the back so that one can make an AM only radio into and AM/FM Radio (like my Magnavox Berkley for example that has an FM Tuner hookup on the back) and I was wondering if that would be a way to hook into a frequency counter for a radio?
Old 08-25-2022, 01:30 PM
Nope. Unless you want to count the instantaneous frequency of the musical notes of your songs or maybe some tiny IF frequency leakage...The audio output is not an Osc test point...It should be obvious to you.
Old 08-25-2022, 06:31 PM
OK, thanks for the heads up.
Old 08-25-2022, 11:31 PM
I take "tuner output" to mean this is either amplified RF or IF from the mixer. It has to be one or the other if you are going to send it to an FM detector.
Whatever it is, it's not the constant high level local oscillator output. You need to measure the local oscillator frequency and subtract 455 kHz from that to calculate the station frequency you are tuned to.
Old 08-26-2022, 01:51 AM
I own the same model of radio and can assure you that the RCA type TUNER jack is a line level audio output for an external amplifier. The inside of the back flap even has the schematic printed on it...I took a picture and used the pencil to point out the jack at the first audio stage.
It's possible if there's no low pass filter to remove the FM MPX stereo ultrasonic carriers you MIGHT be able to plug an accessory FM MPX decoder from a early 60s console, connect it and get FM stereo demodulation, but I haven't tried it or looked for said filter.
What's interesting is it can function as an audio input too. I've been able to tune to a silent channel then back feed the tuner jack through an adapter on the headphone jack on my phone and use my Zenith as an amplified speaker for my phone (it's the secret behind how I played a specific piece of music on that radio in a YouTube video).
Old 08-26-2022, 06:49 AM
OK, I wasn't sure, because I know some of the early add-on tuners like old Pilot FM Tuner from the late 1940s worked where it wasn't necessarily a line-level output that it was outputting to the radio it was being connected to.
Old 08-26-2022, 12:02 PM
kf4rca kf4rca is offline
They sure did make a lot of them.
What you could do is add a digital display, an S meter and a BFO and you would be all set to listen to the pirates on 6925 on Friday and Saturday nites!
You certainly would have enough space in the bottom where the batteries used to sit.
