Old 11-04-2022, 04:34 PM
timmy timmy is online now
Replacement sheet
Old 11-04-2022, 04:35 PM
if they both match from pins 1-5 then this has gotten very strange THOSE are the pins that matter most.
the resistance between 1 and 5
Old 11-04-2022, 04:53 PM
Are you referring to the .45
Old 11-04-2022, 05:12 PM
Pins 1 and 5 measure 1.6 ohms
Old 11-04-2022, 05:13 PM
on both the new and old?
Old 11-04-2022, 05:25 PM
The new flyback 1-5 1.6 ohms same as old one
Old 11-04-2022, 05:58 PM
That one section with the .45 is weird how those coils are configured.
Old 11-04-2022, 07:33 PM
So I guess it’s not a good idea to use this flyback. So I got a line on another new one so I’ll chance another one. The new one that’s no good is a stancor and the one I’m going to get is a thordarson.
Old 11-05-2022, 10:10 AM
I’m not sure why 1&5 would be so important because I do have both boost voltage’s so if those 2 taps were shorted in some way the voltages should be way off at last check 640v was 620v and 770v was 780v that don’t seem to bad but it sure doesn’t explain why the focus circuit is hot even though focus voltage is right and variable via focus coil. And the 66meg stick resistor for focus gets alittle warm as well.
Old 11-05-2022, 10:32 AM
the AC current path of L42 was the reason for looking at the resistance of pins 1-5
http://suzaku.live-evil.org/L42.jpg
not really sure why it's hot if both FBT match, but this may be related to why the 100k ohm resistor burned in the first place.
Old 11-05-2022, 10:45 AM
I had a silvertone that burned the resistor also. Is there a possible reason for the hot L42 from either the horizontal centering circuit or hv regulator like a bad cap. The centering boarders pin 5. Other then that would you use this flyback with the specs it has and the donut 585ohms.
Old 11-05-2022, 11:29 AM
C99 shows.25 but what came out was a .5 this shouldn’t make a difference unless I messed up.
Old 11-05-2022, 11:41 AM
Well it’s official I put the wrong cap in c99 I put a .5 in instead of .25 I don’t know if this may cause the L42 issue along with the video issue
Old 11-05-2022, 12:11 PM
Which would have caused the pulses to be 2x higher then they should have been at that coil , you may want to test r136 too.
Old 11-05-2022, 12:31 PM
Lucky I saved all the caps I changed and there is only one .25 400v c99 and that’s the one I put was wrong. Hopefully the L42 will be ok now and maybe I’ll get video because the pulses pass v6.
