#1261
a13/L7 step 5 in the alignment setup.
#1262
Ok I found it that’s next to the 41.25 trap that was open is this what your saying to adjust the trap or A13
#1263
location can be found on page 6 of SAMS, and shown on schematic page 3 after video det right below C32.
#1264
Yes I know which one it is A13 I know where it is and as for the trap next to A13 that was open I put the knob pretty much where is was befor. But for now I was using wood Allen keys which are no good they strip and don’t work I’m waiting for nylon ones to come in the mail.
#1265
As for the thermistor I’m putting a permanent jumper in because the voltage was to low for to long when turned on and the pilot tuner lamp was very dim and the thermistor was new.my other Motorola I had was jumped as well and was fine.
#1266
https://www.moyerelectronics.com/BVM...8-29822298d228 same thermistor used in the CTC-11, same location, should work the same way.
#1267
The voltage dropped so far I don’t even trust these thermistors because the voltage drops so bad the horizontal oscillator won’t run so my other moto had the thermistor jumped and I since put new nte diodes in 1 kv 2 amp
#1268
thermistors do wear out over time, it's inevitable since they take such a beating, but the exact replacement is hard to find :/
https://talonelectronics.com/shop/item.aspx?itemid=3293 EDIT ==== here is an NOS RCA version of the exact part in your set. https://www.ebay.com/itm/144666189041
=^-^= Yasashii yoru ni hitori utau uta. Asu wa kimi to utaou. Yume no tsubasa ni notte. いとおしい人のために Last edited by Yamamaya42; 12-12-2022 at 12:53 PM. |
#1269
Unrelated on a pilot tv37 there was b+ problems not being up to normal is there one diode or 2 used under the 25z6 3-4 5-8 ok so I didn’t have the schematic in front of me it’s only one diode.
#1271
![]() https://www.earlytelevision.org/pdf/...sams_62-16.pdf
#1272
#1273
It’s to bad I don’t have the 3kp4 crt have to be happy with the green p1.
#1274
I would be happy with any type of Electrostatic deflection type TV to play with, however, the pilot TV 37 is a bit small, it does not stop some putz from asking $1000 for one on greed bay.
#1275
I have 7 Motorola 7 inch electrostatic sets but yes they ask to much for the pilot.
