Old 04-05-2023, 09:40 PM
No, if you have sound but absolutely no vide, I seriously doubt it's the detector. A scope should give you the answer in a few minutes. Start at the detector and go through each stage to the CRT. At some point the signal will disappear and that will be the problem point. I suspect either something is open or shorted.
