Old 05-03-2023, 02:44 PM
Bit more info.
Been trying to find something about the set.
Found...
Thank you for the inquiry. Color unit built 1963-1964 in Plant #2, Greeneville, TN. Apparently it was not a popular seller.
Hope this helps.
Best Regards,
Magnavox Historical Preservation Association
It couldn't have been built in 1963. The Motorola 23EGP22 the first rectangular color CRT didn't come out until around 1965.
Old 05-03-2023, 02:51 PM
Weirder and weirder, if this set is even confusing an expert from the Magnavox Historical Preservation Association!
Old 05-03-2023, 09:23 PM
damen's Avatar
damen damen is offline
1967-68 brochure
Old 05-03-2023, 09:27 PM
1967-68 brochure
don't see a pic. :O
Old 05-03-2023, 09:32 PM
damen's Avatar
Sorry, it won't let me, says I need to resize it, never had to before.
Old 05-03-2023, 09:34 PM
wahh! i wanna see, cause this is a weird one!
Old 05-03-2023, 09:50 PM
damen's Avatar
I'll try again tomorrow. The brochure says it's model 6996 without remote for 698.50, or model 6997 with remote for 798.50. Measurements are 32.5 inches wide, 21 inches deep, and 36.5 inches tall.
Old 05-03-2023, 10:57 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
Originally Posted by nasadowsk View Post
How on earth did RCA, etc get away with one horz output, but others needed two?
Everyone else is like me, and how I live my life. RCA did cheap and easy. I am like Zenith, do it well, do it right, take no shortcuts. 100% opposite. I live my life like Zenith. I go my own way, no shortcuts. I take my own path, with 100% integrity in good design engineering. I do it the hard way every time. I am who I am. Respect this. I respect you, or I flat out don't care!
Old 05-03-2023, 11:37 PM
simple math
2 x 6JM6 tubes, at 17 watts each, which were most likely older tubes most likely BW tvs, or 1 6KD6 at 33 watts. which was made for color sets.
Old 05-04-2023, 08:51 AM
simple math
RCA came out with the 6LQ6 to replace the 6JE6. Later, they came out with the 6ME6, which was a real bomber!
Old 05-04-2023, 01:20 PM
nasadowsk's Avatar
Damn does run fast…
I do remember my grandma’s CTC-38 had an appetite for horizontal output tubes. Maybe by design…
Old 05-04-2023, 03:47 PM
DavGoodlin's Avatar
Motorola Minion
That Magnavox is probably a T933 chassis, a vast improvement over the earlier rectangular color chassis U904, U920, T931.
What a strange cabinet, must have been special order to fit at the right spot in the customer's home.
-Dave G
Old 05-05-2023, 07:54 AM
If so, would make it SAMS folder 1005-1.
Old 05-13-2023, 07:36 PM
Retired Batwings Tech
Ive seen those, part of a living room setting, a weird regional thing. T940 chassis maybe
Old 05-19-2023, 02:06 PM
Things seem to be on track to pick the set up this weekend, had to abandon last week's attempt due to way too much rain over the weekend.
