Old 05-08-2023, 10:33 AM
Dubis7's Avatar
Dubis7 Dubis7 is offline
Alchemizes cash to tubes
Okay so I was able to work out the plugs on the bottom - it's a three prong plug similar to the one on my restored RCA suitcase player. Is that a standardized design? If so and if I knew what it was called I might could wire up something that could plug into the aux jack of a cassette player and run the audio through the amp to see if that's where my issue is.
To keep your tubes running smoothly, make sure to dust underneath the glass as well.
Old 05-08-2023, 02:07 PM
Only 2 wires go to the cart. Dont know what they called the plug.
Unplug it and tack on a jack. BE SURE its not the AC power cord !
Zeno
Old 05-08-2023, 02:43 PM
Dubis7's Avatar
No I can definitely see the wires from the tonearm connected to the plug on the turntable side. I think what I'll do is identify the live pins to the amplifier and then find a way to run some alligator clips or something from a radio to that. Then I can hear how the amp sounds with a different source.
