These sets could be adjusted to run on post war NTSC, and some owners even installed 13CH tuners so I'm not surprised people used them into the 50s. If I wanted to test the CRT regularly I would use a 6-pin socket such as what a type 41 audio output uses as a CRT test socket since that style base is what the 12AP4 uses.... However since I wasn't sure until I saw it, and I had already made my own universal adapter I just used my universal adapter. My universal adapter is basically a base from a dud 10BP4 with labeled color coded alligator clip leads soldered to the heater, K, G1 and G2 pins... I've used that adapter to check 15GP22s, a 12AP4 and other tubes when I don't have the right adapter but can find the datasheet to figure out pinout connection. The sad part is a cabinet in good shape with a postwar TV hacked in went for $100 at the ETF...If I hadn't stopped bidding as I didn't want to waste space on something without it's original chassis I'd have been able to quickly make 1 nice set out of 2...
