Thanks!
Thanks very much! Those are great photos.
Not to be greedy, but it would be great if you could make a couple of quick measurements. I'm sure that your knobs are identical in dimensions to the 30A12. From the photos, I think that the outer knobs are 1.5 inches in diameter, right? What is the diameter of the inner knobs, and what are the depths of the inner and outer knobs (distances from side facing set to side facing you)? If I manage to produce replica knobs that look good, I'll be sure to post the info so that others can benefit. Thanks, Doug |
