Old 07-17-2023, 01:49 PM
Retired Batwings Tech
I'm still wondering why you're going this route to capture in the first place. Plenty of uncompressed capture mediums out there that are far more NTSC friendly such as the digital Betacam format and the Sony DVW-250 portable DigiBeta. Granted its a 4:2:2 with a 10 bit luma sampling frequency of 13.5 MHz and this is going to far exceed the actual resolution capabilities of the M3 on its best day in RGB mode. You will however need to find a way to convert the RGB into either an SDI digital or Y R-Y B-Y to feed the camera connector as very little in the NTSC realm works with the raw RGB signalling
