Old 07-26-2023, 11:53 AM
What I have noticed is that the 6aw8 tube is exceptionally hot for only being on for less then 3 minutes and the color killer don’t seem to kill the color once it’s in sync. That tube is the color killer and tried another tube and the same result.
Old 07-27-2023, 09:04 AM
You do realize the color killers function is to look for the color burst in the recieved sync signal and turn the color off if there is no color burst in the recieved program, right?
There's basically nothing out there designed to send monochrome programming without a burst running* so the killer should naturally be in the color circuit enable state all the time.
* Some people with monochrome TVs will chop up a cable so they can take the luminance coax from the S-video output of a device and use that for burstless high resolution monochrome, but it seems pointless to do for a color set.
