Old 08-04-2023, 09:55 AM
I知 doing resistance checks on the color tube sockets the burst amp every pin is exact to the sams but pin 8 shows 5k but sams shows it should be zero this pin goes to ground. And I知 using the x2 output for negative pin 8 is heater how could it show anything.
V21pin 8 is the cathode of the burst gate, and is tied to ground, resistance check is in reference TO ground. ONLY pins 1,3,6,7 are tested from X2, all else, from ground.
ゥCopyright 2012 VideoKarma.org, All rights reserved.
