Old 08-05-2023, 12:16 PM
That was braced on you mentioning you had color lock, if you do NOT, then A18 has to be tuned until you get lock.
This is NOT the right way to do it, but should get you by.
If you have no color lock, rainbow colors or in some extremes no color, tune A18 until you get lock, and find the sweet spot, tune up and down finding where it locks in and out and tune it in the center of the range that it locks, after that is done, you should not have to touch it again, unless something changes in the set, sometimes changing a tube can cause this to be upset and need adjusting.
THEN
once A18 is set to it's center of it's effective range ( no matter what crystal is in there )
you set tint control to center position, and adjust A19 until colors look correct, red/green, flesh-tones and so on.
