Old 08-11-2023, 08:53 AM
Tuner seems normal using the tuner whatever color is there it will disappear normally and the other way will make color brighter and switching the channel it don’t loose lock as it used to. I tried another xtal Same thing tried the original xtal again and it has distorted colors so I put new one back. The hue makes very little difference don’t change colors as much as it should the intensity works but seems it don’t have the range it had before. It seems very odd that it looks like the xtal went bad and at the same time something else went bad how is that.
