Ok, so I got the video that you guys posted, thanks! I can see the blue, red, & green colors bars moving through the picture "barber pole" style. This is the burst color not locked, or in sync with the local 3.58mhz color osc. I have labeled "A" in my screen shot off your video.... I don't understand the vertical bars in the picture..."B" Are they produced by the defect with this tv? Will your signal source make the same bars on a different tv? If they only show up on this tv..... What happens when you turn down the color... All the way off to B&W....? Do they go away? If those bars only appear on this tv, then I'm wondering if there is possibly something wrong in the burst gate.... Does your color bar generator put some separator between each color...? Anyway, maybe it's a good idea to take a breather from this project for a few days as you said.... To anyone who did not see the video, the blue, Green, & red bars remain at that 30 degree angle, but raise upward through the picture continuously. The vertical bars labeled "B" remain stationary, and are partially effected by the colors passing by - as if they are behind the vertical bars.... Night.... .
Yes you can call me "Squirrel boy" Last edited by Username1; 08-13-2023 at 09:34 PM. |
