The reading of 399 ohms which I will assume was on pin 8, ( you listed pin 7 twice ), is of very little concern, for its common to all Y amps, and comes from R205, and is in tol.
What should be of concern is if the resistance readings for pins 7 on V25/V24 are noticeably different, if they are, then BOTH the 68 ohms resistors should be replaced with a closely matched pair.
