However, I have a Canadian market RCA CTC5 color TV. The set was manufactured in Camden NJ and in Montreal it was modified for 25Hz power. The modification included replacing the power transformer on the main chassis with a 25 Hz filament only transformer and then adding a separate small additional chassis with a massive B supply transformer, an additional filter chole plus two Canadian mad Sprague 80uF 500v electrolytic capacitors. The main chassis had Camden installed Mallory capacitors. When I restored the set in 2014, the Mallory capacitors reformed dielectrics were very low leakage 100uA or less. The Sprague's were close to 1mA leakage at 500v. I left them in and 8 years later one shorted and destroyed a pair of 5U4 rectifiers. I felt at the time the Sprague's were marginal. But the Malloys remain fine. |
It has just reached four years since the restoration. The restoration preserved all the original chassis mount electrolytics and carbon resistors. Only the paper capacitors not shunted by resistors were replaced.
Sixteen paper capacitors and an axial lead 40uFd and capacitor were replaced. Two out of tolerance were replaced with identical type carbon resistors. The only mechanical issue was a loose worn brass fine tuning shaft which I remade and replaced. A full IF RF alignment was done. I switch on the set regularly and it remains in excellent operating condition. The snapshots are from an off air signal this evening. The aim of this thread was to see if the original 77 year old electrolytics would stand up to modern use. As I pointed out earlier in this thread, I took care reforming slowly the original electrolytics. Last edited by Penthode; 09-22-2024 at 12:37 PM. |
Impressive. And equally impressive is the lifetime of these electros!
So many projects, so little time... |
