Old 12-13-2023, 05:30 PM
Aaron H's Avatar
Aaron H Aaron H is offline
Caution, I'm high voltage
Grundig 94U
Would any of you happen to have a schematic for a Grundig 94U table top radio? I've checked radiomuseum, Elektrotanya, and all other online sources, and none have the schematic. Only pictures. Thank you in advance. AARON
"If you want to get away with murder, then you'd better look damned good doing it!" -Me-
Old 12-29-2023, 05:54 PM
Aaron H's Avatar
Grundig 94U
Is there any forum or private source that has a schematic for a Grundig 94U. Thank you in advance. AARON
Old 01-02-2024, 10:41 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Hi Aaron,
I don´t think, that I have a U-version (USA-version) schematic, but I have a german version
of the 94 manual - so far I am sure.
The difference is the power supply 117/220 Volts (most euro-radios have a tap for
110 Volts) and the US-FM-band goes up to 108 MHz.
For the rest I don't see a problem to use the german manual.
Let me know (PM), If you want some stuff for free.
I HAVE CLOSEBY EVERYTHING!
Regards,
TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
