This picture does contain picture information, however, it looks like a AGC problem + Brightness way too high, and is displaying retrace lines. But, since you replaced all the capacitors, as you stated, it can be anything from the wrong part in the wrong spot, mistake in wiring, or something else..... Along with this on the picture, is there quality loud sound? or is it low, or does it have some noise mixed with it? Use clues in pix, & Sound to guide you, + Check your work, + Check AGC. Looks like sync is locked, Video is pretty weak - find the cause. I would say the ion trap is fine for now, and the picture tube is fine too. ----- Addition: When I say it looks like a AGC problem, I mean - If the set were not completely re-caped and you know for sure the circuits were not mistakenly changed to cause this loss of full signal at the point it's lost now..... Start by checking your work - especially signal path near and after the detector circuit + Possibly include the AGC stuff..... Don't discount possible bad tube, open IF Transformer, etc. But first check your own work for mistakes.... .
Yes you can call me "Squirrel boy" Last edited by Username1; 02-26-2024 at 06:08 PM. |
Try turning your room lighting off. Next turn down the TV's brightness control, and see if the picture(contrast) control can give you a more defined with better contrast picture. With the brightness turned down you may get better focus control too. Keep in mind you can't increase screen blackness with the TV's controls unless the ambient room lighting is low. Think of it as a movie projected on a screen, and if you bring the room lights up too bright you loose picture contrast. These early CRT's were never intended to be viewed in a well lit room.
example, my set. http://suzaku.live-evil.org/0226241857b.jpg Taken with VERY bright light on, but then again my 12LP4 is an exception, having spent more than half of it's life in a basement unused!
By golly there is a locked-in picture there. Couldn't see it at first. First thing I would look for is an open peaking coin the video chain, anywhere between the vid detector and CRT. Blooming is generally from HV being lugged down due to a weak HV rectifier.
