Old 03-23-2024, 01:39 PM
Aperna1985 Aperna1985 is offline
Ok so I replaced capacitor C1, the shame of it is the whole thing tested good except the audio filters. I also changed capacitor C62. When i tested it for leakage it tested good then slowly started to leak. I did replace it with one of the yellow plastic ones bevause it was all I had. Cap c62 goes between pin 5 of the video output tube and pin 2 of the picture tube. While it was out I ohmed out coil L50 and it measured 8.5 ohms instead of 7 so I think it's fine. We'll after starting the set up, I now have no picture. There is only 50v coming out of pin 5 of the video Amp instead of 190, pin 11 on the picture tube is showing 1.8v and pin 10 is about 360. I hear the high voltage running. So I'm going to take another Crack at it tomorrow maybe one of the new caps is no good. I tested them all for leakage before install but who knows.
