Old 04-18-2024, 11:47 AM
Findm-Keepm's Avatar
Followin' the Rules...
Originally Posted by rcaman View Post
Why in the he$$ are you buying transistors from Ebay. 99% are junk
+1 , Especially sellers Dalbani, Semitronus and ceitron, pretty much all counterfeit stuff. I stick to the old RCA SK, GE and ECG lines - all of them came before the Chinese dumpex of fakes eBay is so littered with.
In the 90s, Dalbani was a go-to, but in the early 2000s, they suddenly had every video jungle chip out there, all remarked counterfeits.
38+ years in the biz, and I can see a fake a mile away.
Brian
USN RET 22YRS (Avionics/Cal)
Old 04-18-2024, 06:37 PM
luRaichu's Avatar
luRaichu luRaichu is offline
NIGHT STALKER
Really. Everything about the HOTs I bought seemed correct - except for the fact they were of a slightly different package type. The original had a flat top but what I bought came with a bulged top.
So, where would I get a "real" replacement? The original HOT installed was a Matsushita 2SD517.
Old 04-18-2024, 08:37 PM
For me, in the case of TO-3 Horizontal Outputs WITHOUT integral Damper Diode, I use the RCA bagged or boxed 2SD822. RCA bought them by the bucket loads from Toshiba to offer an OEM HOT - in the 1980s. Don't buy them loose or with a shiny top - all 1980s/original 2SD822 transistors were frosty finish. The bagged ones are best, as you can guarantee no swaps with fakes. BTW, all lot "3A" 2SD822s are fakes. Chinese vendors never switched lot codes, and a 2002 produced fake and a current fake, same lot number.
Of note: the later 2000s "SK Series" (no RCA logo) 2SD822s are suspect. Thomson bought and produced a whole line of supposedly OEM transistors, ICs, STRs, and STKs, but many were counterfeit from the get-go.
If you can't find a RCA packaged 2SD822, then go with the SK3710, ECG238 or GE-38, all of which were produced before the Chinese dumpex.
Nearly all of my replacement were bought 1981-1992, so I know my stock of parts is genuine. I can't say that for some servo amp MOSFETs and Transistors I have to buy for current repairs - it's a minefield. eBay simply ain't the answer - unless it's sealed bags from RCA SK Series, GE's Pro-Line Replacements, or ECG bagged / boxed parts. Replacement guide for each is on the Internet Archive site, so cross reference is at hand, free.
NTE has had a rash of fakes - mostly in their STK replacements, some audio power amp transistors and a bunch of their "commodity" (high demand) parts.
Off topic a bit, but still somewhat germane, beware of Motorola transistors bearing post 1999 date codes. As of August 2000, all Motorola production was spun off to OnSemi, with their logo appearing after that date. ONSemi PCN 10143:
"ON Semiconductor will begin the changeover from the Motorola logo to
the ON Semiconductor logo for packaging materials on May 15, 2000
and for part marking on July 15, 2000. This General Announcement
affects all ON Semiconductor part numbers.
Motorola logos will be removed from bar code labels and will not be
replaced with the ON logo (ON Semi bar code labels will be "plain").
For a period of time, you may receive mixed shipments of ON
Semiconductor and Motorola bar code labels, packaging and parts."
And yet, Dalbani will happily sell you a Motorola transistor bearing a 2004 (0420) date code:
https://www.ebay.com/itm/144102545290
Cheers,
Brian
Old 04-18-2024, 09:47 PM
luRaichu's Avatar
NIGHT STALKER
I found one lot of open box 2SD822's on eBay for a better price than what I paid for the 2SD517's. https://www.ebay.com/itm/254620362049 Comes in original old stock boxes. Should I cancel the 2SD517's? Will the 2SD822 be a GOOD 2SD517 replacement?
Old 04-19-2024, 03:30 PM
luRaichu's Avatar
NIGHT STALKER
The 2SD822 seems slightly weaker than the 2SD517. For instance, the 2SD517's maximum Collector-Emitter Voltage is 700v, whereas 2SD822's is 600v.
However, a 13" CRT is pretty small. The 2SD517 datasheet says it's "Designed for use in large screen color deflection circuits". Did the designers of the CT-1310M use a better rated HOT than necessary?
Old 04-19-2024, 03:47 PM
Retired Batwings Tech
More of what was available in mass quantity for the best price in the day. When I was in broadcast those Panasonic 1310's were a staple in the edit suites and were more forgiving than the Sony to poor sync and other issues but they suffered from cracked solder connections mainly around the CRT socket pins and the row of power resistors in the supply chain. The connections may "look" good but in fact may have a slight hairline crack, this is common with TO-220 devices where the center lead expands more and pushes harder than the others being it's the collector and part of the metal tab, power resistors will dissipate a significant amount of heat through the leads. Any time there is thermal cycling there is going to be mechanical stress and you're dealing with 40-some year old wave soldered connections that were the minimum to make the set work then.
If all is well in the other circuits the counterfeit transistors should work just as well as the original.
Old 04-19-2024, 03:52 PM
luRaichu's Avatar
NIGHT STALKER
I canceled my order of 2SD517's from ceitron. I'm gonna use 2SD822's instead.
Old 04-19-2024, 06:12 PM
luRaichu's Avatar
NIGHT STALKER
Never mind, then. I cancelled my order cancellation.
Old 04-20-2024, 09:06 AM
luRaichu's Avatar
NIGHT STALKER
HVSD a.k.a High voltage shut down.
On most sets if it activates the set goes dead. On Panny, RCA Hitachi &
some others of this era too much HV causes the H osc to go off freq.
to reduce HV. Your set is probably like that.
133 volts may be OK but you need to see if it changes. Use a variac
or go from zero brightness to full brite. It must stay the same.
Cause I have seen was always the power supply. Also the B+ control
has to go lower @125 V to put the 130VDC in range.
A manual IS needed now.
Zeno
+B is supposed to be 130v. Sams' schematics courtesy of damen.
Old 04-20-2024, 05:16 PM
Or there abouts, it's never spot on and will vary according to beam current and other factors.
Old 04-21-2024, 07:49 PM
luRaichu's Avatar
NIGHT STALKER
What's normal HOT temp? It was warm last run, but that could be heat from the flyback.
Old 04-22-2024, 01:58 AM
Good question, I guess my rule of thumb is bath water warm but no more than what your fingers can tolerate for say 10-15 seconds. Sorry I can't put a number to this but the HOT itself is known to run warmer than the transistor in these.
Old 04-22-2024, 05:57 PM
luRaichu's Avatar
NIGHT STALKER
New HOT, cleaned CRT pins & reflowed pads on CRT socket, and the TV is still doing the same shit (no lightbulb!). The picture starts normal but then gets too bright & loses H sync. At this stage +B is 131 to 132v. The colors get VERY saturated, and soon Green disappears followed by Red and Blue. Then all you've got is a bunch of monochrome garbage lines dancing across the screen. Sometimes, a bright colorful flash appears indicating something just disconnected. +B jumps to something like 139v in this state, and what once was a fluctuating whining noise becomes a monotonous high pitch. Orange filament glow disappears I think.
Next to the flyback, there is a pot labeled "SUB BRIGHT". Should I bother?
Edit: Just did another test run. The picture lasted for a few seconds but then the magical flash appeared and +B dropped to 127v!
Old 04-22-2024, 06:13 PM
luRaichu's Avatar
NIGHT STALKER
Row of a what now? "supply chain"? What am I looking for
Old 04-22-2024, 09:30 PM
Those big resistors just to the north of the B+ adjustment. Seriously if it was mine I'd go over every solder connection on the board with a touch of solder and replace all of the supply capacitors, they're 40 years old now and not getting any better.
