Old 05-05-2024, 11:46 AM
Originally Posted by Hawkwind View Post
I remember Ads in the back of magazines on how to convert a TV into an O'Scope. Saw one at an Alternator repair/rebuild shop in the '80s...
I could imagine this working with TV yokes for audio bandwidth applications, but I suspect not useful for higher frequencies because of too-high inductance.
Old 05-05-2024, 03:02 PM
One problem is normal CRT's have low retention, scope tubes are high. Picture a dot starting slowly on one side & fading out as it goes. In the olden days there were projects to turn a B&W into a scope.
The other problem is messing with a SS set, you will probably toast many
hoz outputs ! It would be an interesting project but I wouldnt spend
any $$ on it. Alt is keep the normal scan rates & feed it much
like a monitor at the video outs. You will uses low level voltages at that
point & not burn things up.
Old 05-05-2024, 05:01 PM
init4fun's Avatar
init4fun init4fun is offline
Not sure if this is exactly what your lookin for, but here is a video on making a TV/Scope.....
https://www.youtube.com/watch?v=-6CdJQ_Cs_E
