The end sensors need covered as it's exposed to light without the enclosure
There should be reel sensors under each reel. Check the pulse on those. Usually under the reels is a reflector with black stripes.sometimes The black comes off or the reflector is dirty If you clean just use water. The optical sensor it uses may be weak also |
