Thread Tools | Display Modes |
I have two of those, one has the auxiliary speaker (also missing the little crest). Sams covered it in set number 737, folder number 6 dated February 1965.
SPKR may have been sold as an accessory. We had a Zenith mono console
and you could buy a matching amp / SPKR, the TT had a stereo cartridge. MPX adaptors were common add ons but I have only seen a few. Zeno ![]() LFOD ! |
OK, thanks for the info.
I have a question about this stereo, the FM band on this stereo for some reason tunes extremely broad like one station takes up the space of about .7 MHz on the tuning dial (for example one of the stronger stations in my area is at the frequency of 104.7 MHz on the FM Dial and that station on the tuner dial on this stereo spans from where about 104.3 should be on the dial to 105.1 would be on the dial), and the AFC function doesn't seem to be functional on the radio, not even in FM AFC mode, let alone in FM Stereo mode, because the tuner drifts like crazy especially in FM Stereo mode. Would the aforementioned issue be the result of a poorly aligned FM IF Section in the stereo, I would assume the FM section would align similarly to the AM Section except that instead of 455 kHz for the AM Section it would be 10.7 MHz for the FM Section? |
