Old 10-16-2024, 06:58 PM
Chris K Chris K is offline
I thought adjustable had a diagonal through it. I’ve looked in a dozen schematic symbol lists and I can’t find a thing
Old 10-16-2024, 07:28 PM
Penthode's Avatar
Penthode Penthode is offline
There is no real standardization. But in RCA lingo from other equipment, the parallel lines means a ferrite core and the arrows point to where it is to be adjusted.
Old 10-16-2024, 08:42 PM
So what tabs on these things am I shunting with the resistors? I haven’t gotten a clear answer for that. I listed the setup and posted the schematic previously but I didn’t get any information. Is it the up arrow side of the coils being called the primaries?
Old 10-17-2024, 08:57 AM
Penthode's Avatar
The arrows pointing up mean the trap adjustment is on the top of the chassis. The arrows pointing downmeans the adjustment for the stagger tuned stage is made from under the chassis. Each stagger tuned stage has a resonant coil which connects to T102 terminals A/B and T103 terminals A/D, T104 terminals A/Band and T106 terminals D/C.
The resistors are placed across each stagger tuned coil. There is really no primary and I don't know why you are hung up on that. There is the stagger tuned coil and the parallel tuned trap mutually coupled to it. It is clearly identified on the schematic.
Do you understand what you are doing by clipping in place the resistors? It is to eliminate the resonance of the stagger tuned coils so that the remainder of the video IF strip is just an untuned amplifier. This is so you can see independently the tuner over coupled transformer link frequency response when you sweep it. You must try and understand the process so so will be better able to identify and rectify any problems.
Old 10-17-2024, 09:47 AM
I guess this reference in the instructions is why I keep referring to them the way I do:
Old 10-17-2024, 10:09 AM
So the "resonant coil" in this example (T-106) is the coil that's in circuit?
I'm confused. Can you clarify for me the difference between the resonant coil and the stagger tuned coil? You refer to the "stagger tuned stage". I guess that's confusing to me as well.
Basically I think I need to know what is in these cans. For the pictured T-106, the can is literally the stagger tuned stage? The 2 coils within it...the coil between D and C is the resonant coil. Is this correct? What is the other coil, the one that stands alone and is not connected in the circuit? Or am I looking at this the wrong way and I need to think of the 2 coils in the stage as a single item?
Old 10-17-2024, 02:44 PM
Zenith26kc20's Avatar
Yes, d&c are the resonant. The other (without connections to the circuitry) is the trap.
Old 10-18-2024, 05:27 PM
Penthode's Avatar
The arrows pointing up mean the trap adjustment is on the top of the chassis. The arrows pointing down means the adjustment for the stagger tuned stage is made from under the chassis.
Each stagger tuned stage has a resonant coil which connects to T102 terminals A/B and T103 terminals A/D, T104 terminals A/B and T106 terminals D/C.
Here is is again
