Old 11-16-2024, 09:37 PM
Aperna1985 Aperna1985 is offline
Originally Posted by sean View Post
It looks like the wires are pretty much all there going into each socket. It looks like the harness that came with mine. They just spliced the wires together going out to the sockets. I had posted a schematic I made up of the 2972E a few years ago here:
http://videokarma.org/showpost.php?p...2&postcount=20
The wire colors and connections on the 12-pin B&W socket and 14-pin Color socket are in the upper left corner of the schematic.
I was looking at your schematic. I just want to make sure I am understanding it correctly. So Pin 2 of the octal base connector which would be a violet wire would connect to pin 1 of the black and white plug which would be the heater?
It seems like all the yellow wires are disconnected on mine. The drawing that you have doesn't mention any yellow wires. I have three yellow wires coming out of the 14 pin color connector and two yellow wires coming out of the 14 pin black and white.
There's also a white wire coming from the Octal plug that isn't attached to anything.
